Anyone got megasqurit on there 914? |
Ratt |
Sep 11 2003, 05:51 PM
Member Group: Members Posts: 85 Joined: 10-September 03 From: Goose Creek, SC Member No.: 1,136 |
The 74 im picking up has been de-injected. They put on Dual dellotos(sp?). anyways, My friend Jeff is running Megasquirt on his 1971 BMW. The 914 comes with all the original Fuel injection equipment except for the fuel distributer(I think thats what it was). Is it possible to use the stock injection set-up with the megasquirt ecu? Has anyone else done this conversion?
Thanks for any info Andy Rattley |
fiid |
Sep 12 2003, 02:19 PM
Turbo Megasquirted Subaru Member Group: Members Posts: 2,827 Joined: 7-April 03 From: San Francisco, CA Member No.: 530 Region Association: Northern California |
I have a 1.7 (argh) with WB-O2 and Megasquirt.
It runs well, wasn't too hard to do, and isn't too bad for tuning if you use datalogging and MSTweak3K (which is tricky to get going, but I can help you). The only thing I found was vaguely interesting was getting a throttle position sensor. Turns out that a Subaru TPS fits on the D-jet Throttle body with just an adaptor plate ( drill 4 holes in a flat bit of aluminum ). I pretty much removed the D-jet brain and worked out which wires to wire into the MS. The D-jet provides +ve to the injectors where the MS provides ground switching, so I reversed the wiring on the standard wiring harness. If you pull the injector grounds (two of the plugs) (test them all!) from the 3 point ground on the block, you can run them to +ve and then use the wiring from the brain plug to run into the MS. I ran the hose that normally goes to the MPS straight to the pressure sensor on the megasquirt. The Megasquirt board is really easy to build and test. Follow the instructions and you will have a fully functioning board in no time. As the WB02 - it is not as slick as the MS - you have to test a lot of voltage levels and stuff all over the board, and the support is not as good as the MS list. When it is all up and running though, it is very cool. Fiid. |
Lo-Fi Version | Time is now: 12th June 2024 - 03:27 AM |
