Megasquirt MAP pickup, where? Fuel pressure reg too |
yarin |
Mar 19 2006, 08:39 PM
'14-X'in FOOL Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States |
Where did you guys connect your MAP sensor for megasquirt? The throttle body has two ports, but one appears to be blocked by the throttle body at idle and the other is above the throttle plate. Did you guys just adapt to one of the extra nipples(decel valve) off the intake plenum?
What about my adjustable manifold referenced fuel pressure regulator? Is there a stock port to connect to? Thanks |
Mueller |
Mar 19 2006, 11:38 PM
I'm using a port on the plenum......
Lo-Fi Version | Time is now: 11th June 2024 - 11:33 PM |
