A-arm bushings, Pros - cons?? |
East coaster |
Mar 19 2006, 09:48 PM
Senior Member Group: Members Posts: 1,691 Joined: 28-March 03 From: Millville, NJ Member No.: 487 Region Association: None |
What's the best setup for a street car?
Tarret bronze/urethane? (Sounds like a good idea, but never heard from anyone running them) Needle Bearings? ( I worry about rust and maintenance issues) Stock with 40K on them? (Has a low "trick" factor, but probably works good) Delrin/urethane (squeeky........don't want them) Ditto for rear trailing arm bushings???? |
Mueller |
Mar 19 2006, 11:42 PM
the bearing races are hardened to 60R, "if" and when there is wear, it'll be many, many moons down the road...the bearing itself cost $6 each (4X) so what if you have to replace a few 10 years from now??? (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
none of the rubber bushing replacments are perfect, there will always be some sort of comprimise with each solution |
Lo-Fi Version | Time is now: 8th June 2024 - 10:59 AM |
