Megasquirt MAP pickup, where? Fuel pressure reg too |
yarin |
Mar 19 2006, 08:39 PM
'14-X'in FOOL Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States |
Where did you guys connect your MAP sensor for megasquirt? The throttle body has two ports, but one appears to be blocked by the throttle body at idle and the other is above the throttle plate. Did you guys just adapt to one of the extra nipples(decel valve) off the intake plenum?
What about my adjustable manifold referenced fuel pressure regulator? Is there a stock port to connect to? Thanks |
DNHunt |
Mar 20 2006, 09:02 AM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
Yarin
What chip and version of the code are you running? I can post some screen shots of my settings if you are using MS extra. Or I can send the .msq file as an attachment in an Email. That could save you a little time. Funny as it sounds when i first started my original install I used the settings in the default program. It started with info from a SBC. It didn't run well but it got going long enough to start tuning. Dave |
Lo-Fi Version | Time is now: 2nd June 2024 - 03:58 PM |
