Front brake rotor offset, cross over years suck!!! |
Jaiden |
Mar 20 2006, 05:43 PM
Member Group: Members Posts: 346 Joined: 13-January 05 From: Stroudsburg PA Member No.: 3,443 |
Hey all. I got most of the front suspension back on but when I went to put the brake calipers on I noticed that they would not fit over the rotor AND lined up with caliper mounts. SO I removed my new rotors and compared them to the old and found that the rear offset from the rotor surface to the bearing seal surface is deepr on the original rotors.
I had to find this out after I already pressed in the ew bearing races (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) So how can this be? I have the old style strut tubes. When I talked with eric shea about getting my calipers we stated that I have "new" style calipers So what did the factory do? Old strut tubes and new style brakes on a 72? I guess I gotta order new rotor and pull out the races qand return the rotors. Man I hate set backs |
tat2dphreak |
Mar 21 2006, 09:50 AM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
from the info in my notes:
The factory changed the strut housing, ball joint, caliper and rotor at VIN 4722919032 if the VIN is after that, it's the same as a 73+... I've changed all of the front end pieces that are replaceable as maintenance and that has held true... basically the entire front end is a 73 except no sway bar... the U-tabs are there for the bar though... |
