> Stupid Things done while working on a 914., C'mon..... Fess Up!
ClayPerrine
post Mar 23 2006, 11:51 AM
There was a request for a thread on stupid stuff done while working on a 914.
I will start......
I had my six up on my lift working on the rear suspension. I remember looking at the clock and it was about 6:50pm. I stood up to do something (I can't remember what now) and the next thing I know, I am sitting on the floor and my head hurts. I touch my head and I am bleeding. (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) Seems I raised up under one of the rack arms and cracked my head open. I look at the clock and it shows 7:55 PM. (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
At that point, I decided to call it a night.
When I told Betty about it, she had a fit! (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) Her response was "What if you had been holding a cutting torch!!!". Now she insists on checking on me every so often when I am in the garage and it gets quiet for a long time. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Ok... Who's next?
Sparky
post Mar 23 2006, 03:12 PM
Mahna Mahna!
Ok so I eluded to a darker learning period in another thread so here goes (note most of these adventures involved myself and DaveC):
#1. While helping out fellow addict with his 6 conversion we get the /6 in and al buttoned up. Figure we'll take for a test drive and see how it feels. Hmmm oil gauge says 0 pressure at idle. Check oil and it's fine. Engine is a fresh build from a solid shop. Ok bad gauge. Second gauge shows 0 pressure. Man were are we finding these bad gauges?! Third gauge shows 0 pressure at idle also. Ok Let's run her around the block. Get 100 yards down the road and SCREEEEECH motors stops. After owing it back home with Land Rover we discover that someone has the oil lines on wrong, feed to return. I recall someone saying "Are you sure the oil lines are on right?" after the first gauge read zero pressue.
#2. After finishing a head job on my 944 we got the engine back together and I was in the middle of torquing the cam rollers when 2 things happened, first a 45 minute conference call with work. Then Dave's 22 year old daughter pops out with some of her girlfriends all in bikinis. Dave's daughter is a stone cold fox as are her friends. I get back to working on the 944 and notice that I've picked up all of the tools while I was on the conference call. Must be done torquing everything down. So i cal Dave out and we decided to give her a crank and see how she sounds. crank crank crank BANG. #3 piston blows a chunk out of the cylinder wall after shearing off a valve. Seems I "forgot" to tighten the main tensioner pulley bolt with all of the "distractions" around me.
#3. Storing a stripped roller in dad's garage on metal saw horses 36" high. Dad needs it moved 4 feet over closer to the wall so we can put his boat in and do some work on it. I ask Mom to come out and assist, I figure I can just lift the roller while she slides the saw horses over. Working on one end at a time it should be a breeze. We get the front moved over and as we head to the rear of the car i give it a good lift and have it about chest high. Mom crawls under and slides the saw horse over and begins crawling out. The roller starts to slip so I lift more and can feel my left shoulder just ripping away. Mom gets out just as the shoulder gave away and the roller dropped onto the saw horse. While trying to explain all this to my doc he stood there with a stunned look on his face and said "I'm not a vet and I'm not used to treating gorillas." Took almost a year for that shoulder to heal right.
#4. Helping Dave with a fuel injection project on his /6. Using early heads with the injector bosses in the heads he upgraded to PMO throttle bodies. Dave bought injector "plugs" for the heads. We got them buttoned up and I was dialing his Electromotive with my laptop. We got the idle set and I'm trying to tweak a fuel curve and lean into the engine compartment when BANG one of the injector plugs comes flying out and parts my hair. It embedded itself in a ceiling joist. At that point I called it a night and had a very tall scotch. No water, no ice, just scotch lots and lots of scotch.
I've got more but these are the best (?!) so far.
Mike D.
ClayPerrine   Stupid Things done while working on a 914.   Mar 23 2006, 11:51 AM
olav   I was working on my car and my elbow hit my bevera...   Mar 23 2006, 11:55 AM
effutuo101   LOL! Nothing that dramatic. When I was moving ...   Mar 23 2006, 11:58 AM
bondo   Ok, here's a couple I can think of at the mome...   Mar 23 2006, 12:00 PM
!   Screwing a tapping metal screw thru the positive b...   Mar 23 2006, 12:03 PM
jhadler   Just getting ready to finish setting up a crank fi...   Mar 23 2006, 12:07 PM
URY914   I had my dizzy 180 degrees off and shot a flame ab...   Mar 23 2006, 12:14 PM
Mueller   stupid thing: wearing loose fitting sweat pants wh...   Mar 23 2006, 12:15 PM
SirAndy     Mar 23 2006, 12:18 PM
URY914   <...   Mar 23 2006, 12:18 PM
Mueller   stood over the carb on a 914/V8 and poured gas int...   Mar 23 2006, 12:19 PM
URY914   I looked at my car one day and I said to myself, i...   Mar 23 2006, 12:27 PM
bondo   <...   Mar 23 2006, 12:28 PM
elocke   My kids were driving me crazy with croquet mallets...   Mar 23 2006, 12:29 PM
sk8kat1   I too have a sweat pants story car on jackstands...   Mar 23 2006, 12:29 PM
balljoint   All the way under the car, lying on my back, car i...   Mar 23 2006, 12:29 PM
Eric_Shea     Mar 23 2006, 12:29 PM
ClayPerrine   http://www.914world.com/bbs...   Mar 23 2006, 12:38 PM
ClayPerrine   <...   Mar 23 2006, 12:39 PM
toon1   while working on my 914 I alway's thought of h...   Mar 23 2006, 12:40 PM
Carl   Where's that chopstick story when you need it?   Mar 23 2006, 12:44 PM
sk8kat1   .... I plan on doing more work on the teener this ...   Mar 23 2006, 12:45 PM
JOHNMAN   One time I had one up on jackstands (nearly a stri...   Mar 23 2006, 12:48 PM
alpha434   So when I was first learning to weld, I had a bad ...   Mar 23 2006, 12:48 PM
jsteele22   http://www.914wor...   Mar 23 2006, 01:53 PM
ClayPerrine     Mar 23 2006, 02:13 PM
mike_the_man   I'm sure I could come up with several, but the...   Mar 23 2006, 02:15 PM
zymurgist   I agreed to pull an engine and tranny to do a clut...   Mar 23 2006, 02:20 PM
tdsmoonchild     Mar 23 2006, 02:43 PM
tat2dphreak   removing the tar off the floor... I pretty much ha...   Mar 23 2006, 02:45 PM
dinomium   hi, my name is Dino and I am clutz... So I am tryi...   Mar 23 2006, 03:00 PM
mike_the_man     Mar 23 2006, 03:16 PM
Sparky   Nope not gonna do it... Dave also likes to collect...   Mar 23 2006, 03:18 PM
JB 914   letting http://www.914wor...   Mar 23 2006, 03:26 PM
Carl   Well, if you want to get into teenage stupidity â€...   Mar 23 2006, 03:43 PM
Porcharu   <...   Mar 23 2006, 03:58 PM
jhadler     Mar 23 2006, 04:00 PM
Dr Evil   Oh ya, then there was the time I was using a cuppe...   Mar 23 2006, 04:02 PM
Joe Ricard   Brand new 18V Milwaukee drill, 300.00 New Cobalt ...   Mar 23 2006, 04:19 PM
Thomas J Bliznik   I like these stories. Not 914, but a stupid first...   Mar 23 2006, 04:20 PM
davec   You should have seen the look on Mike D's face...   Mar 23 2006, 04:23 PM
majkos   ...   Mar 23 2006, 04:24 PM
balljoint   http://www.914world.com/bb...   Mar 23 2006, 07:41 PM
messix   i'll never admit to anything. if you don' ...   Mar 23 2006, 08:40 PM
Sparky   ...   Mar 23 2006, 08:50 PM
dan10101   Since wrenching for over 30 years, I have quite a ...   Mar 23 2006, 08:54 PM
grasshopper   I need to work on my temper....
  Mar 23 2006, 11:26 PM
JB 914   <...   Mar 23 2006, 11:35 PM
Andyrew   ...   Mar 23 2006, 11:47 PM
JJ914   Well here I go. Carpet in right pass floorboard wo...   Mar 24 2006, 12:37 AM
Porcharu   I could tell you about the time I was gas welding ...   Mar 24 2006, 02:13 AM
alpha434     Mar 24 2006, 05:42 AM
1bad914   Drilling a hole in a piece of sheet metal that I w...   Mar 24 2006, 06:01 AM
zymurgist   A few non-914 adventures from "Ace Mechanic"... W...   Mar 24 2006, 06:23 AM
spare time toys   I had mine up on the roll around table and was mes...   Mar 24 2006, 07:06 AM
jr91472     Mar 24 2006, 07:22 AM
Dead Air   It was my stepmother's '68 MGB, circa 1977...   Mar 24 2006, 09:58 AM
zymurgist   "installing with a hammer" http...   Mar 24 2006, 11:55 AM
Thomas J Bliznik   Real funny stories guys. Things you do when your ...   Mar 24 2006, 12:37 PM
tdgray   Not really any stupid stories yet with the 914 - o...   Mar 24 2006, 01:20 PM
Dr. Roger   914 story. there's a reason they label radia...   Mar 24 2006, 02:19 PM
- Lo-Fi Version Time is now: 1st May 2026 - 04:53 AM
