| seanery |
Feb 22 2003, 08:57 PM
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,857 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
Assume a 901 transaxle and disc brakes for a nice-sunny-day-midwest-summer-car.
Also, Assume I can spell INJECTION correctly! (IMG:style_emoticons/default/huh.gif) -REVISION- Here is the pricing info Beck Spyder. The 2165 motor has a 9mm larger crank. I know in general shorter cranks spin easier, any concerens here? |
| Mark Henry |
Feb 23 2003, 10:06 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
A type 1 hipo engine can be built for the least cost. You can get 120hp+ for a carb engine, if you are going the PEFI route, with proper headwork, you can get 160hp on pump gas easy. Remember this is only a 250lbs. engine with the shroud, fan, alt., etc. Done right with the PEFI system $5500- $8000 depending on size, parts, etc. This is more than enough to smoke the tires on a lightweight car. Don’t know about the trans fitting.
A type 4 with PEFI will cost about 20% more and will give you about 10-20% more power. If you use nickies you may hit the 200hp mark (big maybe) but add $3000 extra to the price. The T4 has a flat torque curve if built right. I don’t know enough about the 6 to tell you what it is worth/hp, the other guys can help you with that. The six will give you higher hp out of a stock engine, so it should last longer than the fours. All the six guys will brag that it sounds better, for what ever that’s worth. (IMG:style_emoticons/default/wink.gif) |
seanery If you were gonna build a beck spyder what motor? Feb 22 2003, 08:57 PM
fuch toy 3.0 + with 200 or more HP.....but then again I... Feb 22 2003, 09:14 PM
drew365 I'd rather build a Beck 904 like Randy Beck is... Feb 22 2003, 10:29 PM
rick 918-S you could always have a Porsche V8...... or not. Feb 22 2003, 10:30 PM
SirAndy i would also go for a bigger 6, 3.0l or more. if y... Feb 22 2003, 10:45 PM
tryan the motor would depend on what size tire you are g... Feb 22 2003, 11:11 PM
Scott If you don't want to throw off the handling wi... Feb 22 2003, 11:52 PM
Alfred
Dave Cawdrey I'm w/ Alferd. The old lady is a 1st place wi... Feb 23 2003, 12:46 AM
Brad Roberts Money..Money.. Money. Build a 2180cc VW type 1 eng... Feb 23 2003, 01:04 PM
Howard ![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:17 PM |
