> Suspension swap, Swap 911/930 front suspension to my 914
spyder9014
post Feb 9 2003, 02:14 PM
What are the benefits of using 911/930 front suspension on a 914.
I have installed gas shocks, turbo tie rods but I have seen it recommended to use the 930 front suspension. Is this just to get the brakes or is this for struts/brakes/torsion bars?
If I upgrade the calipers and rotors will it be just as good as a complete swap?
pnewman
post Mar 25 2006, 08:28 PM
Brant,
Final front end suspension.
1988 struts
New pads, bearings, seals, and flex hoses
New Zimmerman cross drilled rotors. I am painting the rotor hats red.
1988 calipers rebuilt and painted red
koni adjustable red inserts new
197? 911 a arms w/ the old through body tabs for my oem through body sway bar.
- My car didn't come with one thus I will be installing that too.
- I kept the bushings and front and rear brackets from the 88' 911 a-arms as they were in much better shape. I don't like the poly or bronze? bushings as I personally find them to loud as far as transfering vibration.
I have 2 different through body sway bars one oem diameter and another a monster.
my old 74' 914 cross bar in great shape.
turbo tie rods
bump steer kit
all rusty old parts have been dropped off for bead blasting and powder coating in gloss black.
I will post pics when all is assembled.
Pete
spyder9014   Suspension swap   Feb 9 2003, 02:14 PM
J P Stein   Most guys do the 9eleben front end to get bigger b...   Feb 9 2003, 02:51 PM
Jeroen   Early 911 struts have 3" caliper mount spacing as ...   Feb 9 2003, 08:32 PM
Mueller   IMHO.....swapping over to the 930 front end and pa...   Feb 9 2003, 10:52 PM
pnewman     Mar 4 2006, 07:20 PM
brant     Mar 4 2006, 07:41 PM
pnewman     Mar 4 2006, 09:04 PM
Spoke   I converted my 71 914 to 911 a-arms, torsion bars,...   Mar 4 2006, 10:37 PM
brant   All 911's were 19mm in fact its not even reall...   Mar 4 2006, 10:39 PM
army dude   http://www.914world.com/bbs2/h...   Mar 4 2006, 10:49 PM
Aaron Cox     Mar 4 2006, 10:59 PM
Dr. Roger     Mar 4 2006, 11:00 PM
Dr. Roger   prolly swap in some new brake lines while it's...   Mar 4 2006, 11:06 PM
brant   Pete, 19mm would be a good match for 180 rear sp...   Mar 5 2006, 09:24 AM
pnewman     Mar 5 2006, 10:00 AM
brant     Mar 5 2006, 10:34 AM
pnewman   Brant, thanks for the info! h...   Mar 5 2006, 12:04 PM
brant   sounds like you've worked your butt off... tha...   Mar 25 2006, 09:33 PM
Eric_Shea   Bolt on Army Dude, Bolt on.   Mar 25 2006, 10:14 PM
pnewman   Hey Eric! I pressed in your hubs. They are r...   Mar 26 2006, 12:07 AM
Eric_Shea   Glad everything is working out... <...   Mar 26 2006, 08:01 AM
rickyhgarcia   Elephant racing has a great tool in their website ...   Mar 26 2006, 11:27 AM
Dr. Roger   <...   Mar 26 2006, 11:28 AM
rickyhgarcia   Can also check in here: Struts spindler mods...   Mar 27 2006, 11:49 AM
Dr. Roger   andyrew, did u notice on elephants website that t...   Mar 27 2006, 02:45 PM
rickyhgarcia   225lbs...275lbs rear springs? On a lightweight ca...   Mar 31 2006, 05:50 PM
Mueller
  Mar 31 2006, 11:29 PM
rickyhgarcia   Koni Inserts P/N 914/914-6 8641-1077 911 75-8...   Mar 31 2006, 11:30 PM
Eric_Shea
  Mar 31 2006, 11:39 PM
Eric_Shea
  Mar 31 2006, 11:42 PM
rickyhgarcia
  Mar 31 2006, 11:47 PM
Eric_Shea
  Mar 31 2006, 11:48 PM
rickyhgarcia
  Mar 31 2006, 11:58 PM
rickyhgarcia
  Apr 1 2006, 12:15 AM
Eric_Shea
  Apr 1 2006, 12:25 AM
rickyhgarcia
  Apr 1 2006, 12:33 AM
Eric_Shea
  Apr 1 2006, 12:34 AM
army dude   http://www.914world.com/bbs2/h...   Apr 1 2006, 12:50 AM
rickyhgarcia
  Apr 1 2006, 12:56 AM
rickyhgarcia
  Apr 1 2006, 01:35 AM
Eric_Shea   Thanks Ricky for the explanation. Again, as evi...   Apr 1 2006, 11:17 AM
rickyhgarcia
  Apr 1 2006, 12:19 PM
GTPatrick   Eric & Ricky, . . . . . What do you guys mea...   Apr 1 2006, 12:39 PM
rickyhgarcia   ...   Apr 1 2006, 01:03 PM
rickyhgarcia
  Apr 1 2006, 01:33 PM
John Jentz   ...   Apr 1 2006, 02:11 PM
Eric_Shea
  Apr 1 2006, 03:17 PM
soupbone   So the question for me is who can do custom valved...   Apr 2 2006, 01:43 AM
neo914-6
  Apr 2 2006, 02:56 AM
jasons   <...   Apr 2 2006, 08:25 AM
Eric_Shea   Try Jack French at Bilstein he can be reached at 1...   Apr 2 2006, 10:06 AM
rickyhgarcia
  Apr 2 2006, 07:04 PM
Eric_Shea
  Apr 2 2006, 07:58 PM
jsteele22   Just came across this thread. Lots of great info....   Apr 2 2006, 09:24 PM
rickyhgarcia
  Apr 2 2006, 10:12 PM
neo914-6   ...   Apr 3 2006, 09:51 AM
rickyhgarcia
  Apr 3 2006, 09:58 AM
Eric_Shea   http://www.914world.com/bbs2/h...   Apr 3 2006, 09:59 AM
JOHNMAN
  Apr 3 2006, 10:41 AM
Eric_Shea   See the bottom of page 3.   Apr 3 2006, 10:54 AM
Eric_Shea   I also want to be clear on the pricing for revalvi...   Apr 3 2006, 11:06 AM
JOHNMAN   Thanks for the info Eric, I read and re-read the ...   Apr 3 2006, 11:25 AM
Eric_Shea
  Apr 3 2006, 11:30 AM
JOHNMAN   We thank you for your support.   Apr 3 2006, 11:32 AM
rickyhgarcia   This is what they look like before powder coating....   Apr 3 2006, 12:05 PM
rickyhgarcia   Left...   Apr 3 2006, 12:10 PM
rickyhgarcia   Right...   Apr 3 2006, 12:11 PM
Eric_Shea   Pur-deeeeee http://www.914world.co...   Apr 3 2006, 01:19 PM
davep   There are quite a few struts used on the 911 and 9...   Apr 3 2006, 01:46 PM
soupbone   ...   Apr 3 2006, 03:45 PM
Eric_Shea   That's basically it. He does a really nice jo...   Apr 3 2006, 03:55 PM
rickyhgarcia   Some general information on 911 struts and front b...   Apr 4 2006, 05:41 AM
rickyhgarcia   Some more general info:   Apr 4 2006, 06:04 AM
- Lo-Fi Version Time is now: 9th June 2026 - 11:01 AM
