| 2teeners |
Jan 6 2003, 08:27 AM
Member ![]() ![]() Group: Members Posts: 79 Joined: 2-January 03 From: Arlington DFW, TX Member No.: 78 |
<_<
Cost is an object, I don't want to spend big $$$ but a few hundred is Ok. Looking to build a good street driver. If I could find some 1.8 heads I'd use those, so far no luck. I plan on enlarging the exhaust ports on the 1.7 to be more like a 2.0 head, I've never driven a carb'd car, or one without a stock cam. I like low end torque, but an engine that "comes on the cam" a little more than stock would be nice. So what do you guys think? |
| Brad Roberts |
Jan 7 2003, 12:51 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
You said "few hundred"... I dont know of ANY 2.0s that can be had for a few hundred dollars. I would never pick anything but the 2.0... then I would make it a 2056 with the larger 96mm P+C's.
Humm. I know where a good running 2.0 is locally.. carbed for 800$ B |
2teeners I have the parts which should I build? Jan 6 2003, 08:27 AM
Brad Roberts Go with the 1911 carbed. They rock. Very smooth en... Jan 6 2003, 08:21 PM
Gint I had a 1.8 w 96 mm P/C's (1911), 40IDF's ... Jan 6 2003, 10:38 PM
Mueller Ginter,
Did you have that set up in the yellow ca... Jan 6 2003, 11:19 PM
2teeners A mild surprise so far. I thought the 2.0l would ... Jan 7 2003, 12:32 AM
Gint Mueller
Yup, that's the one. Hinkle owns it ... Jan 7 2003, 01:42 PM
2teeners what i meant was I would spend a few hundred more ... Jan 8 2003, 08:22 AM
Brad Roberts Brand new 96's for the 71 crank are something ... Jan 8 2003, 04:33 PM
r_towle read and remember Mar 31 2006, 09:32 PM![]() ![]() |
Lo-Fi Version | Time is now: 30th June 2026 - 05:12 AM |
