got a vac. leak, could it be.. |
toon1 |
Mar 28 2006, 11:08 AM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
I have a vac leak at the runner/ head union. I have replaced the gasket with a new, thick paper gasket. I surfaced the face of the runner where it mates with the gasket with some wet sand paper and a peice of granite tile.
Put it all back together very clean and with a little gasketsinch. When I fired the motor up it was fine. But yesterday after my drive home from work I noticed a fluctuating idle, sprayed some carb cleaner in that area on the rpm went up. Is it possible the runner has a crack?? |
ClayPerrine |
Mar 28 2006, 12:58 PM
Life's been good to me so far..... Group: Admin Posts: 15,514 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
The manifold gaskets are not just paper. They are a plastic insulator between 2 paper gaskets.
You need the proper spacer with the gaskets. It won't run right with just a paper gasket. |
Lo-Fi Version | Time is now: 7th June 2024 - 06:32 PM |
