Megasquirt Update, with PICS |
yarin |
Mar 28 2006, 09:37 PM
'14-X'in FOOL Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States |
I Was about to dig up my old thread from two months ago... but I felt some of these pics deserve there own thread.
I'm really moving along on my upgrade from carbs to MS. I should be able to power up the system this weekend and crank it the following weekend. I chose a rather different approach to my install, a combination of logic, simplicity and durability. Please give me your input. For those who aren't familiar with MS go to www.megasquirt.info and www.msefi.com (forums). I bought all of my Megasquirt parts from DIYautotune.com. Excellent vendor, i suggest doing business with them for anything. What's left: finish db-37 connector connect all wires in relay box mount intake plenum, connect DIY PVC intake install gas tank checked double check and triple check all fuel connections and wiring configure MS crank!! Here are pics: Attached image(s) |
toon1 |
Mar 29 2006, 12:09 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
While thinking about doing this myself I also had the same idea of putting everything in the d-jet case. Hey why not there is a mount there, there is lots of room for both boards and noextra labor in running the wiring through the F/W. I was also thinking you could probably insulate the rest of the box with foam from vibration and heat. |
Lo-Fi Version | Time is now: 4th June 2024 - 08:38 AM |
