| Air_Cooled_Nut |
Mar 29 2006, 01:05 PM
914 Ronin - 914 owner who lost his 914club.com ![]() ![]() ![]() Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
Let's say you and your buddies come across a pile of stock T4 engines (VW and Porsche), what are some easy ways to know what size the engine is? For example, all 1.8 and 2.0 engines have 3 studs to hold the intakes to the head while the 1.7 uses four. That's just an example and I'm not 100% positive that's correct but you get the idea. Thanks!
| dstar |
Mar 29 2006, 01:11 PM
Member ![]() ![]() Group: Members Posts: 196 Joined: 19-January 06 From: Ramstein, Germany Member No.: 5,438 Region Association: Germany |
No, that isn't correct, cause someone could have switched the heads!
Same goes for case numbas......could be anything! The best way is to look at the rods, but by the time you pull the cyls to have a look, you could have measured the stroke and the piston! All engines are cores.......unless they are in a driving vehicle and you can test them....... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Don |
Air_Cooled_Nut Easily & visually find difference 'tween engines Mar 29 2006, 01:05 PM
Mueller 914 four bangers:
1.7/1.8 4 bolt heads (same stro... Mar 29 2006, 01:08 PM
lapuwali 2.0 Bus heads have four bolts, so even the 1.7/1.8... Mar 29 2006, 01:37 PM
Air_Cooled_Nut ... Mar 29 2006, 01:40 PM
dstar ... Mar 29 2006, 01:40 PM
r_towle If I came accross a pile of motors, I would look a... Mar 29 2006, 01:41 PM
Air_Cooled_Nut Mar 29 2006, 01:42 PM
dstar <... Mar 29 2006, 01:43 PM![]() ![]() |
Lo-Fi Version | Time is now: 16th April 2026 - 07:51 PM |
