Megasquirt Update, with PICS |
yarin |
Mar 28 2006, 09:37 PM
'14-X'in FOOL Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States |
I Was about to dig up my old thread from two months ago... but I felt some of these pics deserve there own thread.
I'm really moving along on my upgrade from carbs to MS. I should be able to power up the system this weekend and crank it the following weekend. I chose a rather different approach to my install, a combination of logic, simplicity and durability. Please give me your input. For those who aren't familiar with MS go to www.megasquirt.info and www.msefi.com (forums). I bought all of my Megasquirt parts from DIYautotune.com. Excellent vendor, i suggest doing business with them for anything. What's left: finish db-37 connector connect all wires in relay box mount intake plenum, connect DIY PVC intake install gas tank checked double check and triple check all fuel connections and wiring configure MS crank!! Here are pics: Attached image(s) |
yarin |
Mar 31 2006, 08:17 AM
made some nice progress last night...
i powered up the system through the relay box and cable i installed. Connect it to my laptop, checked a few sensor inputs, it works! I adapted a $10 junkyard throttle position sensor to my stock throttle body. To configure it in megasquirt you simply click get current 0% throttle and then get current 100% throttle at full throttle. BAM, it creates tables and everything. I should be able to finish wiring everything up tonight. The Wideband O2 is waiting to get installed, bnug already welded. That leaves reinstalling the fuel tank, manifold referenced adjustable fuel pressure regulator, tighten the lines and pressure test the system. Aside from that I should have my race seats delivered saturday. I need to order a custom air filter from the auto parts store, should take two days. Slap the exhaust back on, make some config changes in software and BAM... crank and see what happens. |
Lo-Fi Version | Time is now: 4th June 2024 - 03:26 PM |
