> My V8 resurrection is taking MUCH longer than..., ...I planned but what else is new?
neo914-6
post Jul 3 2005, 01:59 AM
neo life
Brad and crew got my 20+ year old Jaide conversion resurrected a couple of years ago but I couldn't leave well enough alone. A fellow V8 converter sold me his built 400hp engine before Christmas and I thought I could get it installed by the April's WCC05 by merely replacing the clutch and rebuilding the old Carter carb. The KEP clutch turned into a fiasco so I decided to buy an all new Renegade kit (less the engine and tranny mounts) besides I already had their great radiator. Bill P gave me some v-belt parts since he was going serpentine and Renegade gave me a nice deal on the w/p for supporting them over the years. Well I come to find this is not a week-end bolt-in so here are my woes and triumphs…
V8 Gurus..., Edelbrock Manifold and Head miss-match
More V8 questions for the gurus..., It's been over 15 years..
Just like "Rides" hot host, designer, and, a team of 40 to work on my car...
Help V8 Gurus! Engine removal..., ...not clearing the axles? V8 topic: Anyone know what header baffles..., ...are used for?
V8 Topic: Help!, Harmonic Balancer not fitting...
Which is better: Renegade or KEP clutch, (or kevlar vs.organic)...
Renegade V8 TOPIC: Shifter?, How did you lengthen it?
GM harmonic balancer differences..., V8 topic
More V8 conversion questions..., ...the rebuild continues
Where to mount a Holley Elect Fuel pump?, in a V8 conversion...
mounting the HEI distributor
"simple" HEI wiring is not so simple to me
V8 topic: front mounted electric fuel pump wiring, ...where to tap 12V?
How do you replace the two shift coupler bushings?, ...just drive the shaft out, is there a pin on it?
Andyrew
post Apr 2 2006, 04:53 AM
Spooling.... Please wait
You could just make that piece... solid aluminum. drill two holes... be done.
Steel would work as well obviously..
neo914-6   My V8 resurrection is taking MUCH longer than...   Jul 3 2005, 01:59 AM
neo914-6   Which brings me to my "July" issues... 1. Per Sc...   Jul 3 2005, 02:08 AM
neo914-6   Notice how "wide" the Jaide engine mount is? Here...   Jul 3 2005, 02:11 AM
neo914-6   2. that hose inlet to xbar is CLOSE...   Jul 3 2005, 02:13 AM
neo914-6   3. My slick Polyurethane engine mounts are "short"...   Jul 3 2005, 02:16 AM
skline   Felix, this is going to sound too easy but, the 1....   Jul 3 2005, 07:11 AM
nine14cats   Hi Felix, Your pump location is very similar to m...   Jul 3 2005, 08:43 AM
neo914-6     Jul 3 2005, 10:02 AM
neo914-6     Jul 3 2005, 03:41 PM
nine14cats   Felix, Here's a few shots of my RH setup from...   Jul 3 2005, 04:49 PM
nine14cats   water pump   Jul 3 2005, 04:49 PM
nine14cats   #2   Jul 3 2005, 04:49 PM
nine14cats   water pump #3   Jul 3 2005, 04:50 PM
nine14cats   WP#4   Jul 3 2005, 04:50 PM
neo914-6   Bill, that hose goes ~300 degrees around the pump...   Jul 3 2005, 05:05 PM
neo914-6   I'm liking AN fittings like on Chris' car....   Jul 3 2005, 05:08 PM
nine14cats   I asked Mike about the routing of the hose. He sa...   Jul 3 2005, 05:08 PM
neo914-6   Bill, Found this 360 degree swivel thermostat hou...   Jul 3 2005, 05:40 PM
neo914-6   Well some progress. Assembled everything to fit b...   Jul 4 2005, 11:05 AM
neo914-6   To make my Jaide engine cross bar fit, I used my d...   Jul 4 2005, 11:12 AM
neo914-6   Still have the w/p inlet pointing up or down into ...   Jul 4 2005, 11:18 AM
neo914-6   Ok, test rotated the water pump like Bills with on...   Jul 4 2005, 07:11 PM
neo914-6   w/p inlet is okay but the fitting is right up to t...   Jul 4 2005, 07:12 PM
neo914-6   plastic 1" are in right orientation but the inlet ...   Jul 9 2005, 12:46 PM
Dr. Roger   Hey hey, Felix! Looking good. We are kinda...   Jul 9 2005, 01:04 PM
neo914-6   http://www.914world.com/bbs2/...   Jul 9 2005, 01:05 PM
neo914-6   Swapped my 1 1/4" and 1 1/2" lines under the car, ...   Jul 9 2005, 01:08 PM
neo914-6   ...   Nov 30 2005, 02:36 AM
neo914-6   Monthly update: http://www.914w...   Dec 29 2005, 02:06 AM
neo914-6   Also, do I leave the space in the u-tab on both si...   Dec 29 2005, 02:09 AM
Crazyhippy   ...   Dec 29 2005, 12:48 PM
neo914-6     Dec 29 2005, 04:42 PM
sj914   You could try a shop that does suspension work. h...   Dec 29 2005, 05:31 PM
BIGKAT_83   http://www.914world.com/bbs2/h...   Dec 29 2005, 06:29 PM
Terryst1   Hi Felix: I was cruising the site and wanted to o...   Jan 1 2006, 07:55 PM
neo914-6   <...   Jan 1 2006, 08:06 PM
Crazyhippy   <...   Jan 1 2006, 08:35 PM
plymouth37   HUH??? I appologise in advance for the impendin...   Jul 30 2006, 11:06 AM
neo914-6   <...   Mar 26 2006, 09:45 PM
neo914-6   I expected to use a hammer on the firewall for val...   Apr 2 2006, 01:07 AM
neo914-6   The fab'd transmission mount ala Brad N Crew w...   Apr 2 2006, 01:12 AM
neo914-6   Looks like I will need to shorten this...   Apr 2 2006, 01:13 AM
neo914-6   Or buy a Renegade adapters and sport trans mount (...   Apr 2 2006, 01:15 AM
Andyrew   You could just make that piece... solid aluminum. ...   Apr 2 2006, 04:53 AM
turbo914v8   I have a set of the Renegade adapters PM me if you...   Apr 2 2006, 10:11 AM
neo914-6   I :smash: clearance for the tall valve covers (th...   Apr 14 2006, 01:45 AM
neo914-6   Forgot to mention, Remil (sj914) came by with some...   Apr 14 2006, 01:48 AM
neo914-6   Found a nice small PSI gauge, mounted the regulato...   Apr 14 2006, 01:51 AM
sj914   Glad they worked for you.   Apr 14 2006, 01:53 AM
neo914-6   Borlas Baby! I am soooo close to fire up. BB...   Jul 3 2006, 09:34 PM
neo914-6   A few issues to resolve before it can be driven bu...   Jul 20 2006, 01:32 AM
Dr. Roger   geez, i was just getting ready to crash and i noti...   Jul 20 2006, 02:13 AM
neo914-6
  Nov 30 2006, 12:23 AM
neo914-6   I actually got some time on my V8 car Sunday. Had...   Apr 3 2007, 01:46 AM
neo914-6   the differences between the bolt-on extension and ...   Apr 3 2007, 01:48 AM
neo914-6   other side   Apr 3 2007, 01:50 AM
McMark   I do my share of 'mangling' stock parts, b...   Apr 3 2007, 03:53 AM
Mueller   Glad it worked...sorry we missed lunch today, hope...   Apr 3 2007, 03:30 PM
Andyrew   Cool! Were still good for saturday? Im slow...   Apr 3 2007, 06:39 PM
neo914-6   Cool! Were still good for saturday? Im slo...   Apr 3 2007, 10:06 PM
Andyrew   Chris is getting his ultima next week? SWEEEEET...   Apr 3 2007, 10:39 PM
neo914-6   Andrew and Dan came by to help with the shift rod ...   Apr 7 2007, 07:20 PM
dan10101   We copped out on the trip to Chris'. My foot ...   Apr 7 2007, 11:58 PM
neo914-6   We copped out on the trip to Chris'. My foot...   Apr 8 2007, 12:16 AM
neo914-6   Engine start video / audio   Apr 15 2007, 08:13 PM
neo914-6   The buyer finally picked up my 25+ year project. ...   Nov 18 2007, 02:14 AM
dlo914   :( :wavebye:   Nov 18 2007, 02:24 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 02:28 PM
