> need electrical guru, bug
firstknight13
post Apr 5 2006, 06:29 PM
ok car runs great!!! then i notice tach not working so i pull over and replace blown fuse. turn on key pop fuse blows . i repeat and same thing happens.... i have all lights , NO turn siganals; NO dash lights; NO NO NO......
with key off and turn signal on left or right side the lights for signaling will go on NOT flash??? if you can help would be appreciated!! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) I'm not an electrician so tell it to me in simple lingo please (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Spoke
post Apr 5 2006, 07:37 PM
Jerry
A couple of questions:
Which fuse blows?
What year is your car?
Does the fuse blow when the key is turned on with the lights on or off?
Did you recently do any work in or around any wires or on the dashboard?
Do you have a multimeter?
BTW, I think it is normal for the signal lights to be on continuously if the turn signal is left in the turning position. I've noticed this on my car too.
If you can see your turn signals on with the key off, then the turn signal wires would seem to be ok.
Spoke
firstknight13   need electrical guru   Apr 5 2006, 06:29 PM
lapuwali   Somewhere, you have a short. Either a wire is dis...   Apr 5 2006, 06:34 PM
firstknight13   i looked at the wiring diagrams and too many too c...   Apr 5 2006, 06:38 PM
john rogers   Could be goop in the steering column area of the t...   Apr 5 2006, 07:31 PM
Spoke   A couple of questions: Which fuse blows? What ye...   Apr 5 2006, 07:37 PM
SirAndy     Apr 5 2006, 07:59 PM
firstknight13   this is great the response that is !!...   Apr 5 2006, 07:59 PM
Spoke   Hmm... My Haynes repair book lists fuses S1 to S8 ...   Apr 5 2006, 08:26 PM
Spoke   OK, I found S9. Nevermind the previous post. Spok...   Apr 5 2006, 08:31 PM
kdfoust   http://www.914world.com/bbs2/html/e...   Apr 6 2006, 07:50 AM
rhodyguy   where are you pulling power for your fuel pump fro...   Apr 6 2006, 10:08 AM
firstknight13   i have a tach now but no brake or turn signals. I ...   Apr 6 2006, 10:04 PM
elocke   Tach wire on wrong coil terminal?   Apr 7 2006, 08:13 AM
Spoke
- Lo-Fi Version Time is now: 14th April 2026 - 06:00 PM
