> need electrical guru, bug
firstknight13
post Apr 5 2006, 06:29 PM
ok car runs great!!! then i notice tach not working so i pull over and replace blown fuse. turn on key pop fuse blows . i repeat and same thing happens.... i have all lights , NO turn siganals; NO dash lights; NO NO NO......
with key off and turn signal on left or right side the lights for signaling will go on NOT flash??? if you can help would be appreciated!! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) I'm not an electrician so tell it to me in simple lingo please (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
post Apr 5 2006, 07:59 PM
Resident German
QUOTE (Spoke @ Apr 5 2006, 05:37 PM)
Does the fuse blow when the key is turned on with the lights on or off?
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) a few things ...
first, with key *off* your blinkers don't blink. they're used for "parking lights". so that's normal ...
second, did this happen with the lights on? i know your lights were working, but did the fuse blow with the lights on?
if so, test with lights off. if the fuse doesn't blow with the lights off, i know what your problem is ...
(IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Andy
firstknight13   need electrical guru   Apr 5 2006, 06:29 PM
lapuwali   Somewhere, you have a short. Either a wire is dis...   Apr 5 2006, 06:34 PM
firstknight13   i looked at the wiring diagrams and too many too c...   Apr 5 2006, 06:38 PM
john rogers   Could be goop in the steering column area of the t...   Apr 5 2006, 07:31 PM
Spoke   A couple of questions: Which fuse blows? What ye...   Apr 5 2006, 07:37 PM
SirAndy     Apr 5 2006, 07:59 PM
firstknight13   this is great the response that is !!...   Apr 5 2006, 07:59 PM
Spoke   Hmm... My Haynes repair book lists fuses S1 to S8 ...   Apr 5 2006, 08:26 PM
Spoke   OK, I found S9. Nevermind the previous post. Spok...   Apr 5 2006, 08:31 PM
kdfoust   http://www.914world.com/bbs2/html/e...   Apr 6 2006, 07:50 AM
rhodyguy   where are you pulling power for your fuel pump fro...   Apr 6 2006, 10:08 AM
firstknight13   i have a tach now but no brake or turn signals. I ...   Apr 6 2006, 10:04 PM
elocke   Tach wire on wrong coil terminal?   Apr 7 2006, 08:13 AM
Spoke
- Lo-Fi Version Time is now: 14th April 2026 - 06:00 PM
