| yarin |
Apr 6 2006, 07:40 AM
'14-X'in FOOL ![]() ![]() ![]() Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States |
I'm going to crank the car tonight but I want to make sure i have my baseline settings correct.
(IMG:http://www.megasquirt.info/ms2/MT_injector2.GIF) Installing MS II V3.0 on a '73 2.0 (4cyl, port injection, 4 injectors, low impedence injectors, speed density). My required fuel came out to be around 13. (122 cubic inch, 4 inj, 24 lbs/hr) Stock 2.0 injectors, plenum, runners. Do I want 2 or 4 Injections per cycle? Injections per Engine Cycle is set the number of squirts you want per engine cycle. You want this to be set so that your idle pulse width is no less than 2.0 ms, if possible, and your Req_Fuel is less than 15-18 milliseconds, but more than 6 milliseconds. These values allow proper tuning of the idle mixture while maintaining the ability to apply enrichments (acceleration, warm-up, etc.) under full throttle. This is the total injector events that you wish to occur for every engine cycle (360 degrees for two stroke engines and 720° for four strokes. What about injector staging? Alternating or Simultaneous? (alternating is my guess) Even fire or odd fire? (i say even fire according to MS II documentation) Do I setup my injector banks as follows? INJ1 - Cyl 1, 3 INJ2 - Cyl 2, 4 This is the firing order of the dizzy: (IMG:http://www.914world.com/bbs2/uploads/post-2-1120702620.jpg) i believe the dizzy numbering is incorrect but the sequence is right. I plugged into the calculator here: http://www.megasquirt.info/v22manual/mfuel.htm Disp 122 cubic inch, 4 cyl, 4 inj, 4 squirts, 24 lbs/hr, alternating, gas. That gave me Req Fuel of 13.3ms and downloaded req fuel of 6.7. This satisfies the required fuel range above of 6-15ms. So are these settings acceptable? Thanks |
| DNHunt |
Apr 6 2006, 07:44 AM
914 Wizard? No way. I got too much to learn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
Yarin
I use 4 per cycle, alternating. Check the number of cylinders you have. It should be 4 and 4 injectors. Dave |
yarin Megasquirt Injection Control setting Apr 6 2006, 07:40 AM
crash914 ok, I am running the following...
required fuel ... Apr 6 2006, 07:50 AM
yarin Ok so i'm on the right track, i'll see how... Apr 6 2006, 08:14 AM
agrump Mine, 2056cc with 1.7 injectors Apr 6 2006, 08:18 AM
yarin whoah.. pretty large range of configuration that w... Apr 6 2006, 09:41 AM
Bleyseng Yep, Djet is ol school but ya just turn the little... Apr 6 2006, 12:26 PM
yarin Ahhh crap... go figure, i missed something:
Howev... Apr 6 2006, 01:26 PM
crash914 ummmmmm....
I am using the negative side of the c... Apr 6 2006, 03:45 PM
lapuwali The tach signal for a fuel only setup shouldn... Apr 6 2006, 03:49 PM
agrump The tach signal only needs to be synced with the c... Apr 7 2006, 06:24 AM![]() ![]() |
Lo-Fi Version | Time is now: 22nd June 2026 - 09:02 AM |
