| firstknight13 |
Apr 5 2006, 06:29 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 652 Joined: 25-March 05 From: manchester,ct. Member No.: 3,817 |
ok car runs great!!! then i notice tach not working so i pull over and replace blown fuse. turn on key pop fuse blows . i repeat and same thing happens.... i have all lights , NO turn siganals; NO dash lights; NO NO NO......
with key off and turn signal on left or right side the lights for signaling will go on NOT flash??? if you can help would be appreciated!! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) I'm not an electrician so tell it to me in simple lingo please (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
| rhodyguy |
Apr 6 2006, 10:08 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
where are you pulling power for your fuel pump from? when the engine is running, and you press the brake pedal, does the tac drop to zero and the gen light come on?
k |
firstknight13 need electrical guru Apr 5 2006, 06:29 PM
lapuwali Somewhere, you have a short. Either a wire is dis... Apr 5 2006, 06:34 PM
firstknight13 i looked at the wiring diagrams and too many too c... Apr 5 2006, 06:38 PM
john rogers Could be goop in the steering column area of the t... Apr 5 2006, 07:31 PM
Spoke A couple of questions:
Which fuse blows?
What ye... Apr 5 2006, 07:37 PM
SirAndy Apr 5 2006, 07:59 PM
firstknight13 this is great the response that is !!... Apr 5 2006, 07:59 PM
Spoke Hmm... My Haynes repair book lists fuses S1 to S8 ... Apr 5 2006, 08:26 PM
Spoke OK, I found S9. Nevermind the previous post.
Spok... Apr 5 2006, 08:31 PM
kdfoust http://www.914world.com/bbs2/html/e... Apr 6 2006, 07:50 AM
firstknight13 i have a tach now but no brake or turn signals. I ... Apr 6 2006, 10:04 PM
elocke Tach wire on wrong coil terminal? Apr 7 2006, 08:13 AM
Spoke ![]() ![]() |
Lo-Fi Version | Time is now: 14th April 2026 - 06:00 PM |
