> Megasquirt STARTS!, my engine IS a fuel pump :/
yarin
post Apr 6 2006, 08:21 PM
'14-X'in FOOL
Megasquirt II V.3.0, Porsche 914 2.0. Fuel only, stock distributor, pertronix ignitor driving stock coil, no extra resistors, no R57, no pullup resistor. Stock 2.0 injectors, low impedence using PWM.
I got the car started, it idled like crap but held on. I ran though about 5-6 10 seconds runs with the car idling, probably at around 2k rpm. Its running pig rich, blowing gas out the exhaust. This is why I didnt leave the engine running for too long. I know some of the settings must be WAY off. Maybe its from cranking and not starting excessively. My wideband read full rich. I heard stumbling and popping out the exhaust. The exhaust was literally blowing gas all over. This oil is definitely not going to see any road time, maybe a few more runs to get idle ok then its getting dumped. I bet a decent amount of gas snuck by the rings. Anyway.. onto my major issues:
I attached my log files.
*RPM looks pretty valid, no major spikes. It holds around 1700-1800RPM. This is with the Fidle valve open but blocked off. Why so high?
*MAP didn't drop below 65, perhaps i have a bad leak somewhere?
*ignore AFR, i know its full rich. some runs the sensor didnt have time to heat up.
*How can I be certain the injectors arent stuck open? It's a 4CYL horizontally opposed engine, MS has two injector banks, which bank goes to which cylinders?
*Someone please double check my setting and make sure i'm on the right road here.
*I noticed that when i turn the key to the on position the fuel pump runs but then dies after a few seconds. the relay board kills power to the pump which is also tied to my coil power. is this normal?
*I setup my required fuel to 10ms after seeing it run pig rich, 2L engine, injectors at 24lb/hr, 4, 4, alternating, even fire. the injectors are rated for about 24lb/hr at 3bar. i'm running them at 2bar.
*my injector characteristics are set to 1.1ms open time, 0.10 ms/v compensation, 78% PWM current limit, 1.1ms PWM time threshold, 66us injector PWM period.
If there is any more info that i'm missing please ask and i'll do my best to help you guys help me.
This project is really friggin awesome! I can't wait to get this thing tuned right and running. Thanks in advance!
(IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif)
Attached File(s)
Attached File  megasquirt200604062057_idle.msq ( 16.44k ) Number of downloads: 51
mightyohm
post Apr 7 2006, 03:36 PM
What timing... I installed my Megasquirt V2.2 last night and got all the sensors working. I haven't tried to fire the engine yet (it was late!). I found Easytherm to be a big PITA. At one point I screwed something up and ended up with a bootloader on the MS, and that was it. I had to use Hyperterminal to upload the firmware. That was a little scary! When I was done, my CHT and IAT read within 2 degrees so I was pretty happy...
Maybe tonight I will get it to fire. I am expecting a lot of tweaking because I don't know if my engine is a stock 1.7 or not. It always ran lean so I suspect it might be a 1911 or have a strange cam. So I will be tuning it purely by AFR/feel.
Jeff
yarin   Megasquirt STARTS!   Apr 6 2006, 08:21 PM
yarin   914club wont let me attach excel files. whats up w...   Apr 6 2006, 08:22 PM
jsteele22   I've got nothing useful to say, except it...   Apr 6 2006, 08:52 PM
turboman808   I watched someone tune a car from nothing. Man wh...   Apr 6 2006, 09:12 PM
yarin   hmm. ok yikes... PWM should have been set for ~30%...   Apr 6 2006, 09:12 PM
Tom Perso   I think I found 1.7L injectors (rebuilt) for aroun...   Apr 7 2006, 04:30 AM
DNHunt   Get the tuning screen open and get busy. Tune it a...   Apr 7 2006, 06:57 AM
crash914   Good job... don't worry too much. the fuel p...   Apr 7 2006, 07:05 AM
bd1308   way to go man! http://www.914w...   Apr 7 2006, 07:16 AM
yarin   Your 55kpa MAP at idle makes me feel a bit better....   Apr 7 2006, 07:55 AM
DNHunt   Yarin My stock engine idled at about 35 KPA so yo...   Apr 7 2006, 09:32 AM
jsteele22   <...   Apr 7 2006, 09:43 AM
yarin     Apr 7 2006, 11:00 AM
crash914   I have a pretty big cam, so the high vacuum readin...   Apr 7 2006, 11:04 AM
jkeyzer   What timing... I installed my Megasquirt V2.2 las...   Apr 7 2006, 03:36 PM
Mueller   good job.....my 1st install I screwed something up...   Apr 7 2006, 03:58 PM
Gint   Nice work. Keep posting your progress please. I...   Apr 7 2006, 05:54 PM
yarin   ran it again till it warmed up. tuned the fuel out...   Apr 7 2006, 05:58 PM
yarin   Here is a closeup plot of part of my last idle run...   Apr 7 2006, 09:06 PM
- Lo-Fi Version Time is now: 1st August 2025 - 05:41 PM
