| JPB |
Apr 7 2006, 05:33 PM
The Crimson Rocket smiles in your general direction. ![]() ![]() ![]() ![]() Group: Members Posts: 2,927 Joined: 12-November 05 From: Tapmahamock, Va. Member No.: 5,107 |
I messed up and assumed that original sway bars for 73's on were at least 19mm. OOPs! Tell me the facts here because mine says 15 at the end and 125$ later .......was it a bad choice? My 914 is a 71 and has no sway bar so 15mm can't be bad right. Its just for street anyways. Speak or forever hold your peace.
(IMG:http://www.914world.com/bbs2/html/emoticons/popcorn[1].gif) |
| Eric_Shea |
Apr 7 2006, 07:51 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Yes. 15mm is stock. I like that bar for the street. Porsche made an 18mm bar for the 76 Turbo that was through body. Used 'basically' the same hardware (arms were a bit beefier and the drop links are a different length). You could order a replacement from Porsche for around $125 buck I think... (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
JPB Are 15 mm sway bars original? Apr 7 2006, 05:33 PM
Bleyseng Yes, the oem ones are tiny. Atleast use a 17mm for... Apr 7 2006, 05:35 PM
Mueller any front bar is better than none at all.....
pri... Apr 7 2006, 06:04 PM
JPB Ya, at least it came with all the hardware all in ... Apr 7 2006, 06:14 PM
anthony Did you get front and rear bars? Stock 914 2.0L ca... Apr 7 2006, 07:03 PM
JPB I only have the front ones right now. I'd lik... Apr 8 2006, 05:31 AM
Mueller Apr 8 2006, 06:00 AM
JPB Thanks. I will read.
http... Apr 8 2006, 06:23 AM![]() ![]() |
Lo-Fi Version | Time is now: 10th December 2025 - 08:03 AM |
