Gosh dang it! My clutch will not release completely anymore, It didn't used to havfe this problem.... What's up with that? |
Dr. Roger |
Apr 19 2006, 12:25 AM
A bat out of hell. Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
When everything went in the car (V8 engine/trans) it was new.
I adjusted everything per the best specs available. (found here and from Renegade) When i first ran her engauging first gear was no problem. Now, 100 miles later, it seems to be getting harder and harder to get 'er into first gear. I've adjusted the clutch cable to the point of riding on the clutch plate/TO bearing. any more and the clutch would start to disengauge. (IMG:style_emoticons/default/blink.gif) i've watched the clutch lever go back and forth and it looks like everything moves smoothly. i did, however, bend the clutch fork a little during assembly because i thought iti needed to in order to mate the engine/transaxle. (IMG:style_emoticons/default/slap.gif) so now what do I do?? oh, i've got a RH flywheel and TO bearing, a kennedy clutch plate and pressure plate. I'm feeling pretty stumped on this one...... (IMG:style_emoticons/default/confused24.gif) |
racerx7 |
Apr 19 2006, 12:36 AM
Member Group: Members Posts: 119 Joined: 28-January 06 From: Belmont, CA 94002 Member No.: 5,489 |
Check the clutch tube on the firewall. Mine was real weak. It used to move, then one day it broke. (IMG:style_emoticons/default/WTF.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 09:14 PM |
