Drain plugs in the . . . FLOOR - what are the good for?, Absolutely nuthin' |
Mike McGrath |
Apr 19 2006, 04:43 PM
Member Group: Members Posts: 98 Joined: 5-December 04 From: Portland, Oregon Member No.: 3,225 |
I have stripped out damn near all of the black soundproofing from my floor panels.
I was able to pry out the front left drain plug, which was leaking anyway, but the other three are still covered with that gray goop and they just ain't coming out without some serious BFH'ing and scraping all day long. My question is - if there isn't any leaking apparent / no rust channels or anything, do I need to bother getting them out? For the one that is out, I figure I'll just weld in a piece of sheet metal to fill the hole and seal it. TIA, Mike (in Portland) |
Brad Roberts |
Apr 19 2006, 05:25 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Seam sealer. All body shop supply places will have it in a caulking tube configuration. I use 3M products typically.
I personally dont believe POR15 is enough to seal them. I also believe you can get the expanding style seam sealer that closely resembles what the factory used when they built the cars...either way you will need to spread it around. B |
Lo-Fi Version | Time is now: 7th June 2024 - 12:39 PM |
