McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
How much weight can typically be transferred when corner balancing a car? Can you transfer 10 lbs from front to rear? 25 lbs? 50 lbs?
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,249 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
my finals. about 1/4 tank, drivers weight compensated. i don't know where the height measurements were taken. very slight rise on the dr rear w/o driver.
488(570mm) 484(580mm) 642(544mm) 561(552mm) front: caster L 5.47* R 5.22* camber L -1.51* R -1.54* toe L .07" R .06" total .13" (this was a drastic change out from the initial settings) rear: camber L -1.77* R -1.73* toe L .13" R .12" total .25" thrust angle .02* this setup seems to work well on a primarily street/freeway driver, which is what i opted for. k |
Lo-Fi Version | Time is now: 11th July 2025 - 07:33 AM |
