Build your own Combo (904) Gauge, Parts 1 and 2 |
914forme |
Apr 23 2006, 06:48 PM
Well here it goes the step by step instructions on how to build one of the kits. Since I helped do the original production run, back in the day, its been about 11 years ago since we did these. But there is interest in it so I will show you how.
Step one, the original kit. It included a gauge face, a backing plate and a ground lug. Also included instructions on how to do this, and some of the items where real PITAs to do. I will included some changes I do, and items that might make the installation a little easier. Attached image(s) |
914forme |
Apr 23 2006, 07:58 PM
Now onto the real fun, takeing the bevel apart. The pros just cut them off you are about to see why. First remove the rubber surround. Next you need to have a gental touch and don't worry about the paint that flakes off, thats fixable. You strat by gentally twisiting your screw driver, I made a special tool for this I have since lost. (IMG:style_emoticons/default/confused24.gif)
Move the bevel metal out a little at a time. A trick I use is I only go around the bevel , 2/3rs of the way. With some minor struggle it will come off. And then you have less to repair latter. Take your time here. It is worth it in the long run, trust me. (IMG:style_emoticons/default/biggrin.gif) Attached image(s) |
Lo-Fi Version | Time is now: 5th June 2024 - 01:32 PM |
