Sideshifter linkage question, can I install console shifter boot with engine in car? |
Borderline |
May 4 2006, 10:07 AM
Senior Member Group: Members Posts: 720 Joined: 8-February 05 From: San Juan Bautista, CA Member No.: 3,577 Region Association: Northern California |
I just bolted up my new rebuilt side shifter to the engine and want to get it back into the car. I don't have the rubber booty thing that fits over the connection at the transaxle. Can I install it after the engine is in the car. It doesn't look like there is enough room to slide the shifter rod far enough forward to get it out of the bushing. This is on a 4 cyl with the where the rod goes through the hole in the engine mounting crossmember.
Thanks for the help. (IMG:style_emoticons/default/smile.gif) |
SLITS |
May 4 2006, 10:27 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
You need to remove the cone screw from the rear shifter cup and slide it off the rear end of the bar and then you can remove the whole bar from the car.....just like you do when you drop the drivetrain out of the car.
Lo-Fi Version | Time is now: 8th June 2024 - 08:29 AM |
