> How to properly wet sand clearcoat?
Steve Thacker
post Sep 23 2003, 10:29 AM
UMMMPH Yea Baby Yea ! UMMMPH
Does anyone know of a link and or could explain how to "properly" wet sand clearcoat? I'm wanting to do my own, to save some cash.
Thanks!
Slowpoke
post Sep 23 2003, 09:05 PM
I read the link at repair nation. That was all good info. But, a couple of things I do. Get a spray bottle and spray water on the car with it as you sand. Less wringing our of sponges and it still flushes away the clear that is sanded loose, and I don't get as wet as when I use a hose.
I find it easier to control the sand paper at an edge than a 8 inch buffer, so I sand near an edge carefully with only 2000grit. Then I use a 4 inch buffing pad on a die grinder on low pressure. It removes less material and if you press too hard it just stops. So I don't burn the paint. Heat is what buffs the car, and it will also burn the paint so I check the tempt of the panel with my hand as I buff, it slows me down and takes more time but, I never burn through yet. I also use the spray bottle again to cool it down or wet the compound.
Buy a good buffer. The more you sand with 2000 grit the less wool buffing you have to do. Get at least 4 of foam pads for the finish. Everyone buffs a little different and I surely don't think mine is the best, but it works for me.
Steve Thacker   How to properly wet sand clearcoat?   Sep 23 2003, 10:29 AM
vortrex   go to the forum at www.autobodystore.com and ask o...   Sep 23 2003, 10:30 AM
Chris H.   autopia.com is good too.   Sep 23 2003, 10:59 AM
Steve Thacker   Thanks! I tried the autopia.com, but it points...   Sep 23 2003, 12:04 PM
tdgray   Steve, I might be able to help if you tell me wha...   Sep 23 2003, 12:24 PM
Steve Thacker   Found a awesome site! http://www.repairnation....   Sep 23 2003, 12:30 PM
Steve Thacker   Todd, I just had my car freshly painted last month...   Sep 23 2003, 12:37 PM
vsg914   Steve, The learning process of color sanding and b...   Sep 23 2003, 04:27 PM
p914   Here's another link from a DIYer http://www.au...   Sep 23 2003, 05:05 PM
p914   Check out a votech school that does bodywork to ge...   Sep 23 2003, 05:47 PM
Steve Thacker   Thanks for the wake-up call VSG. I'll get a ol...   Sep 23 2003, 06:15 PM
tracks914     Sep 23 2003, 07:42 PM
vsg914     Sep 23 2003, 08:19 PM
RD Evans   Take a look at Autobody Store. Very active BBS wi...   Sep 23 2003, 08:31 PM
Slowpoke   I read the link at repair nation. That was all go...   Sep 23 2003, 09:05 PM
Chris H.
- Lo-Fi Version Time is now: 13th July 2025 - 05:01 PM
