Brad, tranny problems pics |
Bleyseng |
Sep 22 2003, 07:44 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Can't call, but if you can help figure this out, great.
Geoff Attached image(s) |
Bleyseng |
Sep 24 2003, 09:04 AM
OK, I did the adjustment yesterday. I just didn't have the correct spacing between the 3 shift rods (where the red arrows point). I used feeler gauges to adjust the space inbetween them, about .012 inches.
You first set up the 1st/Rev rod correctly so the funny gear that hangs off the rear cover doesn't hit the main 1st drive gear (about .010). Then you set up the middle shift rod, first adjusting the shift fork and slider so its in the middle of 2nd/3rd. This means that it is at rest as it spins and not resting on a syncho. Then adjust the rod spacing and alignment in relation to the 1st/rev rod. The notch must line up and then spacing is .012. Then you do the same thing with the 4th/5th gear rod, first adjusting the shifting fork and slider. Then adjusting the shifting rod in relation to 1st/rev and 2nd/3rd, aligning the notch in the rod. Then you set the rod spacing off the 2nd/3rd rod (.012) with the feeler gauge. In rebuilding my tranny, I changed many parts but I didn't change anything with the diff/pinon. Setting the diff backlash/pinon depth needs a shop I hear. Is yours bad? Probably not, use should be able to install new syncho's, the two bearing in the intermediate plate, and atleast new dog teeth in 1st, 2nd gears. Sliders are what you will have to inspect to see if you need them. (probably atleast a 1st gear slider) Geoff |
Lo-Fi Version | Time is now: 11th June 2024 - 08:33 AM |
