Hammy |
mr. Wonderful ![]() ![]() ![]() Group: Members Posts: 1,826 Joined: 20-October 04 From: Columbia, California Member No.: 2,978 Region Association: Northern California ![]() |
Mounted the pump today. Is this the right spot? I judged by pictures I've seen but I also read your pump needs to be lower than the tank (?).
Is that even the right filter to use? This is what they recommened at Napa. I put some gas in and ran the pump and there was no leaking anywhere. so just making sure, did I get everything right? Attached image(s) ![]() |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 14,991 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
If you have carbs, that filter is OK. If you have fuel injection, that filter is not. It is not made for high pressure and flow, and will either clog up quickly or burst. Not happy, as you can imagine.
The location is OK as well. That is more or less in the factory location, which worked pretty decently. (Looks like someone got a little bit POR-15-happy!!) --DD |
Lo-Fi Version | Time is now: 16th June 2024 - 04:06 PM |
