Bartlett 914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest ![]() |
My car has starting to run a little rough last week. Today is is totally down. It acts like it is running on 2 cylinders and won't idle. The points were pitted so I replaced them with the cap and condensor. The plugs were black. 2 were totally wet (3 + 4) and have been replaced. I have changed the ECU, MPS. and the coil. The fuel pressure is up around 29. Any suggestions?
Mark |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Check injectors. If they are gummed up they will drool the fuel out instead of atomizing it and you will get soaked plugs. If trigger points are bad you will likely get nothing on the plug/run lean if at all.
Lo-Fi Version | Time is now: 11th July 2025 - 01:21 PM |
