> Running problem, Suddenly acts like running on 2 cyl
Bartlett 914
post May 8 2006, 11:28 AM
My car has starting to run a little rough last week. Today is is totally down. It acts like it is running on 2 cylinders and won't idle. The points were pitted so I replaced them with the cap and condensor. The plugs were black. 2 were totally wet (3 + 4) and have been replaced. I have changed the ECU, MPS. and the coil. The fuel pressure is up around 29. Any suggestions?
Mark
So.Cal.914
post May 8 2006, 04:37 PM
"...And it has a front trunk too."
If you find that the F I is ok ,I would check the valves. I have had valves tighten up and the valve does not close, causing compression loss. On a four cyl. it will seem that you have lost two cyl's.
(IMG:style_emoticons/default/smoke.gif)
Bartlett 914   Running problem   May 8 2006, 11:28 AM
bd1308   D-jet or L-Jet Fi? if D-jet, I would look at your...   May 8 2006, 11:40 AM
Dr Evil   Check injectors. If they are gummed up they will d...   May 8 2006, 11:45 AM
Heeltoe914   Check the two or three grd wires at the center of ...   May 8 2006, 04:27 PM
So.Cal.914   If you find that the F I is ok ,I would check the ...   May 8 2006, 04:37 PM
Bartlett 914   Thanks for the input guys. I am still having prob...   May 8 2006, 05:11 PM
Bartlett 914   I think I found something. #1 110 #2 110 #3 0 #4 ...   May 8 2006, 05:43 PM
Bartlett 914   I am so Bummed! I cannot get any clearance on ...   May 8 2006, 07:49 PM
So.Cal.914
- Lo-Fi Version Time is now: 11th July 2025 - 03:04 PM
