> Gear Choices for a 901, Looking for advice on what gears to run with a 3.0
Nick
post May 10 2006, 07:19 AM
I did some searching on this topic and didn't come up with much. I tried to find Brad's gear / speed chart but the links to it all seem broken. Basically I'm looking for some ideas on what gears I can run in the 901 that would be a better match with the 3.0. I would like to run it as a 5 speed so Ideally I'd like a first that is taller than stock and a 2nd that is taller than stock, maybe tall enough to take me to 60 mph at 6500 rpms.
Nick
TimT
post May 10 2006, 09:48 AM
retired
What is the intended use of the car?
For street you would want to go with longer gears ie Z or ZD fifth
For track you want to tailor the box to each track. since it isnt very economical to swap gear boxes/gearset between races (although some do) chose a gearset that works in a wide range of applications, but still lets you use the torque of the engine.
Short tracks, KQV seem to be popular.
Longer tracks, MSX are popular gearsets.
Nick   Gear Choices for a 901   May 10 2006, 07:19 AM
dekman   Nick, I have a 3.0L(cosworth pistons 9.8:1./ E cam...   May 10 2006, 07:52 AM
dekman   Add: At 3800 my speedo says 80mph.(at 6000 it say...   May 10 2006, 07:55 AM
Dave_Darling   Realize that in a 901 box, 2nd gear is a part of t...   May 10 2006, 08:33 AM
Dr Evil   Yup, much easier and less $$ to do a 4 s...   May 10 2006, 08:42 AM
J P Stein   The GA mainshaft is relatively common....I recentl...   May 10 2006, 08:44 AM
TimT   What is the intended use of the car? For street y...   May 10 2006, 09:48 AM
smontanaro
- Lo-Fi Version Time is now: 2nd April 2026 - 03:29 PM
