OEM electronic distributors for the Type 4?, What was used on other VWs? Cap'n? |
lapuwali |
May 25 2006, 12:02 PM
Not another one! Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
I'm gathering parts for my Megasquirt conversion, and I believe some later VWs (Bus or Vanagon?) used OEM electronic ignition in the distributor. This true? Which models?
Note that advance curve, vac advance, etc are all completely immaterial. I'll only be using the distributor to trigger the ECU and, uh, distribute the spark. Advance will be set by the ECU (advance mech. in the distributor will be locked). I could engineer this using one of the many 009s I have on the shelf, but using an OEM distributor would be a lot easier. Cap'n? I'm sure you'd know... |
lapuwali |
May 25 2006, 02:42 PM
Cap'n Krusty |
May 25 2006, 03:13 PM
CA market 79 busses and Vanagons 80-85 should work. You can lock down the vacuum advance plate and the mech advance. Later will fit and might work, but I dunno. The Cap'n |
Lo-Fi Version | Time is now: 8th June 2024 - 09:58 AM |
