starter sticks "ON", a new one of rme..... |
Dr. Roger |
May 25 2006, 12:28 PM
A bat out of hell. Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
i just replaced the starter switch with an aftermarket dash mounted type.
the starter just got a little adjusting to allow the starter gear to throw a little furthur inward. I can bench start the starter and the solenoid moves the starter gear where it should be and the gear starts spinning. looks fine to me. i install the starter and wire it correctly, testing the wiring with a volt/oohm meter. then i go to turn over the motor with the ignition disconnected. i turn the key to the acc position and everything comes on. then i turn the key to the start position and the engine starts turning over. but when i release the key, the starter continues to turn over the engine. (this is where i preach the importance of having a main power shut off switch) LOL could it be the stupid switch? it releases under no load senario. (IMG:style_emoticons/default/confused24.gif) |
Brian_Boss |
May 25 2006, 04:08 PM
Member Group: Members Posts: 324 Joined: 3-June 03 From: Dallas, TX Member No.: 781 |
I'm betting it's a sticking solenoid on the starter.
Lo-Fi Version | Time is now: 7th June 2024 - 03:52 PM |
