starting problems, i think i found the source but can always use opinions |
modpr2 |
Jun 2 2006, 03:47 PM
Newbie Group: Members Posts: 38 Joined: 27-April 06 From: Orange County, CA Member No.: 5,941 |
sometimes my 914 starts sometimes it doesnt. it usually starts when it has not been driven for awhile (atleast a couple hours). but always fails to start if i shut it off then try to start it up again right away. it will always start if i push start it and it will stay running so i think i have a bad starter. what do you think. thank you
draperjojo |
Jun 2 2006, 10:55 PM
sixstrings Group: Members Posts: 411 Joined: 26-December 05 From: Salt Lake City Utah Member No.: 5,317 |
If its turning over than the othe thing you want to rule out is a compression problem. I had the same problem once and it turned out to be bad rings. I did a compression test that came out low, so I did a "wet & dry test" to determine that in my case it was rings. Chances are with the 914, you need the hot start kit though.
Lo-Fi Version | Time is now: 10th June 2024 - 07:27 AM |
