alternator woes, is nothing simple? |
nycchef |
Jun 5 2006, 06:37 PM
mechanical moron Group: Members Posts: 952 Joined: 28-November 05 From: new york city n.y. Member No.: 5,202 Region Association: None |
alternator is not charging battery. changed relay board today. here's the rub. ran the car for an hour or so . got home and battery was dead. jumped it from my other car . started right up. removed pos battery connection and it stalled. thought alternator was no good but it runs the car but will not charge.
ClayPerrine |
Jun 5 2006, 07:54 PM
Life's been good to me so far..... Group: Admin Posts: 15,498 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
In addition, you may have a bad voltage regulator.
Charge the battery. Start the car. Put a volt meter on the battery. Pull the regulator. Jump the field lead to the D+ lead. If your alternator is good, you should see 16 to 18 volts on the meter. If it does show that, replace the regulator. |
Lo-Fi Version | Time is now: 1st June 2024 - 05:31 AM |
