Spring is Sprung, The Grass is Riz,, And the rear end of my car is as crooked as a.......... |
balljoint |
Jun 5 2006, 11:18 AM
914 Wizard Group: Members Posts: 10,000 Joined: 6-April 04 Member No.: 1,897 Region Association: None |
914 with a ride height 1.5" shorter on the passenger side at the wheel well.
Does that rhyme? New springs and the problem is solved right? 100-140 lb? Are there a number of different manufacturers that make springs that happen to be the correct size and I should just poke around or is there a preferred manufacturer (or un-preferred). Also, and in addition, I happen to have a brand-spankin' new set of Koni Yellows that came with the '71, never installed. Is there any difference from the '71 to the '74 as far as the rear shocks go? Gracias in advance Chicos and Chicas, |
Aaron Cox |
Jun 5 2006, 08:28 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
is the front sagging??? broken torsion bar can do that....
if its just the rear.... i have no idea... |
Lo-Fi Version | Time is now: 6th June 2024 - 09:02 PM |
