| davep |
Jun 8 2006, 05:21 AM
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,359 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
I just picked up a pair of 944 Turbo calipers that need a bit of work. This is the first of these calipers for me to play with. While the early 911 "S" caliper is aluminum, and I have several of them, they are bare aluminum with no protective finish I have noticed. These Turbo calipers are a lot different. They are painted and plastic dipped. The plastic is peeling off in places. Further, there are plates that fit on either end of the pads that are fastened in place with Allen key bolts. To separate the caliper halves, the 4 main bolts must be removed, plus these bolts and the cross-over brake line. The bolts inside look like they will be very difficult to remove. The plates themselves look like stainless steel.
So, any tips for disassembly? Any tips for cleaning & refinishing? What is required to install on a 911 strut (bolt spacing is wider than the 911 "S")? |
Jeroen yup, the plates are SS
those allen bolts are a PIT... Jun 8 2006, 06:45 AM
RON S. Dave,
I recently stripped apart a front set of... Jun 8 2006, 07:22 AM
davep Is there a good site that has photos of all the di... Jun 8 2006, 10:45 AM
Jeroen
TimT The rebuild lits can be got direct from Brembo.. o... Jun 8 2006, 12:18 PM
davep
Eric_Shea
davep Best parts prices I've found so far are:
... Jun 9 2006, 07:50 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:40 PM |
