Best 3-day weekend ever. This is what I did, 914-6 gets power. |
Heeltoe914 |
May 30 2006, 12:12 AM
Senior Member Group: Members Posts: 1,135 Joined: 31-January 06 From: Tujunga Calif, Member No.: 5,506 |
Had the best Three-days ever. As I said good-bye to all and closed myself into the garage. Its been 2.5 years sence I started converting my factory 6 two a 3.2 race mod motor. Its not that it took that long its just I seem to never have time to work on my own projects. So I passed on parties, works and a hot set of legs to spend 28 hrs this weekend on my car and the motor is now in. Suspension is all attached and now the interior goes to the shop.
Yes those are 16x9, and the brakes are 944 turbo, RSR front 23mm torsion and 250 rear to start. LSD and gears. Sway bars are front Charlie bar and rear 19mm both slide adj. Front oil cooler with fan and Miron oil filter. This is where it is now. I call her Indy sence she made me miss the race. As you can see I dont care much about concours as much as going fast. Attached image(s) |
Heeltoe914 |
Jun 10 2006, 03:24 PM
Update for you DIY guys. Did some fitting today on rims and valance. and the MAS with MSDs air cleaner. next is the wiring of 3 VDOs 2 1/16th size in the stock fuel gauge location.and a Mallory rpm gauge with limiter. The whole in valance will be filled. front rims will be 7s and rears 9s as you can see. Also adding the upper longs reinforcment kit.
Attached image(s) |
Lo-Fi Version | Time is now: 10th June 2024 - 05:31 AM |
