GrnEyedLdy |
FEAR ME! ![]() Group: Members Posts: 10 Joined: 2-December 05 From: Hershey, PA Member No.: 5,223 ![]() |
Sorry, Noel was still logged on....and I can't delete this for some reason
Ok, how? I now understand what Ed was saying about cutting an access hole in the fire wall. What a PITA. I would pull the vacc advance, plug it and rev to 6K. When I would adjust the dizzy it would run worse or better then worse (over the spectrum; bad-good-bad), but it would not move the timing visually. I have a couple of questions: 1. Do I need to adjust the timing to the RS cams that I had installed? 2. What is that value? 3. Anyone want to come down and do it for me? |
LvSteveH |
I put the Poor in Porsche ![]() ![]() ![]() Group: Members Posts: 1,080 Joined: 22-April 03 From: Las Vegas, Nevada Member No.: 600 ![]() |
I had to deal with this yesterday. Take the time to setup the flywheel with the appropriate marks for TDC, 120 degrees, 120 degrees. Then, no mirrors, and much more accurate.
The only hard part is getting it to perfect TDC, it's a little tough to get with a mirror and an odd angle. I also verified physically by using a TDC indicator. Not sure I like the tool, but it does work, even if you don't have any other marks to reference. |
Lo-Fi Version | Time is now: 5th July 2025 - 09:43 PM |
