GrnEyedLdy |
FEAR ME! ![]() Group: Members Posts: 10 Joined: 2-December 05 From: Hershey, PA Member No.: 5,223 ![]() |
Sorry, Noel was still logged on....and I can't delete this for some reason
Ok, how? I now understand what Ed was saying about cutting an access hole in the fire wall. What a PITA. I would pull the vacc advance, plug it and rev to 6K. When I would adjust the dizzy it would run worse or better then worse (over the spectrum; bad-good-bad), but it would not move the timing visually. I have a couple of questions: 1. Do I need to adjust the timing to the RS cams that I had installed? 2. What is that value? 3. Anyone want to come down and do it for me? |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,906 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
try just makin richer or leaner with the mixture screw (1/4 turn is alot) never know might work. dont loose track of where you start if you turn the screw. you can do it while running. Here you go: http://forums.pelicanparts.com/showthread....ture+adjustment |
Lo-Fi Version | Time is now: 5th July 2025 - 09:18 PM |
