BMXerror |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,705 Joined: 8-April 06 From: Hesperia Ca Member No.: 5,842 ![]() |
As a sign of how bad this afternoon is going, I'm writting this post AGAIN because F*CKING WINDOWS DELETED MY OLD ONE, just before I added it to the forums. (IMG:style_emoticons/default/ar15.gif)
Anyway, here goes again. The facts: The fuel pump runs when you turn the key on, and when the starter's running. All the fuel lines are clear both in the loop, and to and from the tank. The pressure regulator's clear. The port on the fuel rail to test the pressure is clear. And there's a gallon of new gas in the tank. The problem: NO FUEL PRESSURE! Zero. Zip. Nilch. nada. NONE! To compound my frustration, after fighting with this thing for two weeks, including six hours yesterday after work, it finally ran for thirty minutes strait with no fuel leaks! It was actually running a little rich. Today I try to start it up and NOTHING.... AGAIN. Yesterday, what I thought I found was that the send and return lines to the fuel loop were hooked up backwards. I wasn't positive, but after looking at the pump flow in the manual, it looked like it was hooked up wrong. I switched it, and that's when it ran. I haven't changed anything since. Lemme see if I was right. On a 1.7 fuel pump, the line from the tank goes into the only port that flows in (the side without the valve). The send line to the loop goes out the middle port and across to the pressure regulator behind cylinder #1. After the fuel loop, the return line comes down and hooks to a T fitting. The T also hooks to that last port on the pump (the side WITH the valve) and the return line to the tank. Is this right? Is there anyone out there who has a clue what my problem might be? I'm about ready to go insane here. Please help before you lose a brother to the loony-bin. (IMG:style_emoticons/default/screwy.gif) Mark D. |
swl |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada ![]() |
fuel supply -> filter -> non valve side of the pump -> center port of the pump -> passenger side fuel rail -> drivers side fuel rail -> pressure regulator -> valve side of the pump tee'd to fuel return
If I read you right it sounds like you have the supply going to the pressure regulator rather than the fuel rail. but if that is so it would never have worked at all - I'm confused too. |
Lo-Fi Version | Time is now: 7th July 2025 - 12:45 AM |
