| 914rrr |
Jun 16 2006, 11:25 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,038 Joined: 1-July 03 From: Knoxville, TN Member No.: 874 Region Association: South East States |
I have a suspect ignition switch in my teener. Haynes manual exploded view is so small it's worthless. Clymer only has proceedure for 914-6. Anybody have a good resolution exploded view of the steering column components and / or a step by step? Is the key/mechanical portion still available? I know the electrical switch still is. Does having AC complicate things?
| URY914 |
Jun 16 2006, 12:05 PM
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 132,073 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Rob
Is it an early car or late? The later ones are pretty easy, I've taken mine apart several times. I've never done an early one and I think they are different. He is what I know: It helps to remove the S/wheel. Look under the column, there is a the allen head bolt. Remove it and you can remove the cover plate that goes around the switch/lock. You can remove the lock cylinder and then remove the small slotted screw that acts as a set screw for the ig. switch. The switch slides out pretty easy. I'm doing this from memory but I know most of the above is right. It's about a 4-5 on a scale of 10. |
914rrr 914-4 Ignition Switch Replacement -How to? Jun 16 2006, 11:25 AM
914rrr Paul,
Thanks for the reply. 914 is a '74 (la... Jun 16 2006, 02:29 PM
Dave_Darling For 72-74 cars, just follow the procedure in the P... Jun 16 2006, 04:30 PM
Thack I took some pics from my '76. The switch is in... Jun 16 2006, 06:08 PM
914rrr Thanks to all, especially Dave! That is a grea... Jun 16 2006, 08:11 PM
Joe Ricard Piece of cake for a late one.
As a matter of fact... Jun 16 2006, 08:37 PM
914rrr :bump:
Anybody know how to remove the 930S horn ... Jun 17 2006, 10:33 AM
Joe Ricard It all is removeable with :sawzall: or :smash: Jun 17 2006, 02:29 PM
Dr. Roger Google says:
The horn pad is attached to steering... Jun 18 2006, 04:09 PM
914rrr Thanks Doc, and all. Horn pad came of by simply tu... Jul 3 2006, 10:48 AM
GWN7 I just did the same repair.... if the lock is worn... Jul 3 2006, 10:57 AM
GWN7 Here's my post on this from the bad grounds th... Jul 3 2006, 11:03 AM
914rrr I went to the Porsche dealer. He gave me the (VW) ... Jul 3 2006, 06:38 PM
914rrr :bump: Jul 3 2006, 11:54 PM
GWN7 Download the PET from the Porsche site and look fo... Jul 4 2006, 04:29 AM
JPB Wow, 930 wheel is on top of the sexy charts. Bett... Jul 4 2006, 07:39 AM
Thack I should have took pics and wrote down the disasse... Jul 4 2006, 02:34 PM
914rrr ![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:18 PM |
