hi4head |
Member ![]() ![]() Group: Members Posts: 69 Joined: 4-April 06 From: Lexington, NC Member No.: 5,819 Region Association: None ![]() |
OK - I got the opossum taken care of and have figured out the windshield washer system, now time for a real problem.
Since the car has been sitting for the past eight years without a battery, I put a fresh battery in about 1-1/2 weeks ago. Friday I noticed that the battery was about dead. I figured that maybe we'd left the cabin light on or something and didn't give it much thought, just hooked up my trickle charger and let the battery recharge. Yesterday it was about dead again and I started growing suspicious. I figured something was either making contact and it shouldn't be, or I had a bad battery. I've disconnected that battery and hooked my multimeter up to the positive strap and the ground strap. I would expect that it should show an open circuit, but no, it shows that current can be passing. When I flip the cabin light switch on, it shows no resistance (as expected). I've left the meter connected and started going through various visible connections and points in the system. (i.e. disconnected each of the connections on the relay board in the engine compartment, removed each of the fuses there and on the fuse board under the steering wheel, disconnected the clock) Nothing that I've done has changed the resistance level shown on the meter. Anyone have any ideas on how to procede? Thanks, Chris |
swl |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada ![]() |
yep. You've got a leak somewhere. Modern cars will have a 'parasitic' load - one that is always there even with the car turned off. Things like keeping your presets on the radio or powering your car alarm. The 914 though really has nothing that should be operating with the switch off. James has got the right plan. Pull the fuses and check with meter in current mode. You can isolate the FI electricals and the ignition with the 12 conductor plug in the back passenger side and the 4 conductor in the back drivers side of the relay board.
Lo-Fi Version | Time is now: 9th July 2025 - 12:30 PM |
