center console wiring in all factory harnesses, where do i find this in my harness? |
arc914 |
Jun 20 2006, 07:48 PM
Member Group: Members Posts: 139 Joined: 9-April 05 From: Sault Ste Marie,on,Canada Member No.: 3,905 |
hey hey
I bought a used centre console and i thought i read somewhere that all harnesses had the connectors pre-wired incase you wanted this option. well i wanted this option but on a quick review of the underside of my dash and the floor wiring i found nada. is this true or am i searchung for sometin that is not there? i have a 73 914-4 help a brotha out with your knowledge andrw in the Soo (IMG:style_emoticons/default/WTF.gif) |
tracks914 |
Jun 20 2006, 08:31 PM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
I agree with Andy, My early 73 doesn't have the wiring and neither did my 72 but it was easy to install. The hardest part was getting the temp sender and taco plate for the underside of the engine.
For the rest you just need a constant "hot" wire for the clock, an ignition "hot" wire for the voltmeter and tap off that same hot wire to go through the temp guage and continue on back to the temp sender unit under the engine. The brown wires all go to ground and the last wires are for the lights. They can be hooked to the dash lights. Not a big deal at all. |
Lo-Fi Version | Time is now: 17th June 2024 - 12:30 AM |
