Need metal guidance (cowl seams), It's not the best place on the car.. |
redshift |
Oct 2 2003, 09:09 PM
Bless the Hell out of you! Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
I have a 1.7 that is all laid out in pieces for a redo.
I am having the cowl seams welded up, and my problem is not understanding what all that joint has going on. From the door jamb, it looks like the rust line is deep in there, what do you think should be done to make sure that is fixed?. It's not cakey rust, it's just a line that continues down between the metal parts that meet there. Thanks, I've never done anything like this before, I am scared I'll go overboard, or not far enough. It's the not knowing. Miles |
sj914 |
Oct 2 2003, 09:52 PM
Senior Member Group: Members Posts: 805 Joined: 20-August 03 From: San Jose, CA Member No.: 1,053 |
Well, you can always use a steel wire brush on a drill and see if it gets the rust out. Or you could just bite the bullet and pull the fender off. Without a pic I can't tell if its the same spot I'm thinking of.
Lo-Fi Version | Time is now: 9th June 2024 - 06:29 PM |
