DonTraver |
Senior Member ![]() ![]() ![]() Group: Members Posts: 829 Joined: 5-August 04 Member No.: 2,461 ![]() |
Pulled my ignition switch today, found one of the two screws holding the mechanical and electrical parts together was missing. Installed both screws now the switch is working. BUT when I got the switch out there was a red wire with a female spade on it that came loose from somewhere.
Tested all the circuits, the only thing not working now is the turn signals, so I think the red wire has something to do with them. The color of the wire is red, I opened the harness connector, the wire has a "R" cast into the plug. When I turn the switch to the on position the red wire is hot. Any help is appreciated. Thanks, Don |
lylegd |
Newbie ![]() Group: Members Posts: 49 Joined: 19-August 04 From: Fort Collins, CO Member No.: 2,574 ![]() |
Don, the red wire goes to terminal #15 on the main light switch not the hazard light switch. When running jumper wires, I would suggest you include an inline fuse in your jumper wire to avoid problems. Lyle
Lo-Fi Version | Time is now: 9th July 2025 - 04:15 PM |
