KEP V8 conversion kit - pilot bearing, If you have it, OK if not flush? |
cobra94563 |
Jun 22 2006, 12:23 PM
Chris Group: Members Posts: 341 Joined: 1-March 05 From: San Francisco Member No.: 3,696 |
I got the conversion kit with the project.
(IMG:http://www.geocities.com/cf30@sbcglobal.net/adapter3.jpg) The pilot bearing has an aluminum washer thing (in pic) is about 3/4 thick. When I removed the part from an sbc 350, the rear surface of the bearing was flush with the rear edge of the crankshaft (?). On the engine I'm installing it on, ('64-65-ish chevy 283) the crankshaft area where the bearing goes, is not as deep and the bearing doesn't fit in all the way, - sticks out 1/8 to 1/4". But I'm think it is fully seated. Anyone run into this or do you think that is OK ? (assuming the tranny can mate all the way to the engine).. Thanks Chris (IMG:style_emoticons/default/smash.gif) |
1bad914 |
Jun 22 2006, 12:43 PM
Senior Member Group: Members Posts: 618 Joined: 6-May 04 From: Battle Creek, MI Member No.: 2,028 |
Some of the older cranks are tapered, KEP sells the one that fits that tapered crank. Mine was a 1967 327, they said it was a small percentage of these that had the taper.
Lo-Fi Version | Time is now: 9th June 2024 - 09:17 PM |
