DonTraver |
Senior Member ![]() ![]() ![]() Group: Members Posts: 829 Joined: 5-August 04 Member No.: 2,461 ![]() |
Pulled my ignition switch today, found one of the two screws holding the mechanical and electrical parts together was missing. Installed both screws now the switch is working. BUT when I got the switch out there was a red wire with a female spade on it that came loose from somewhere.
Tested all the circuits, the only thing not working now is the turn signals, so I think the red wire has something to do with them. The color of the wire is red, I opened the harness connector, the wire has a "R" cast into the plug. When I turn the switch to the on position the red wire is hot. Any help is appreciated. Thanks, Don |
brp914 |
Unregistered ![]() |
my -6 had a problem where #9 fuse would blow when signaling rt turn. I found that there is a strip of metal bent up on the dash frame that is likely to catch a stray terminal from the hazard switch. I bent the terminals up to keep them out of danger and havent had a problem since. good luck.
Lo-Fi Version | Time is now: 9th July 2025 - 03:15 PM |
