> 914-6 ignition switch wiring, Red wire (R) where does it go?
DonTraver
post Jun 21 2006, 07:03 PM
Pulled my ignition switch today, found one of the two screws holding the mechanical and electrical parts together was missing. Installed both screws now the switch is working. BUT when I got the switch out there was a red wire with a female spade on it that came loose from somewhere.
Tested all the circuits, the only thing not working now is the turn signals, so I think the red wire has something to do with them. The color of the wire is red, I opened the harness connector, the wire has a "R" cast into the plug. When I turn the switch to the on position the red wire is hot.
Any help is appreciated.
Thanks, Don
DonTraver
post Jun 23 2006, 12:41 AM
That diagram is great. It just told me what the wire is for, right now it's just capped with a male spade fitting. It's not hooked up, just capped, I wasn't going to do anything with it until I was sure. My turnsignals still don't work, but now I know it's a separte problem. Thanks I really appreciate you help.
Later, Don
- Lo-Fi Version Time is now: 9th July 2025 - 03:24 PM
