Tire question... Pressures and temps, Yokohama A0032R S compound |
ConeDodger |
Jun 24 2006, 10:10 AM
Apex killer! Group: Members Posts: 23,612 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I am running a set of Yokohama A0032R S compound tires on my stock 2.0 liter Fuchs. They are 205 50 15.
I have run one event on them and just for starters I ran 35psi all the way around. After my first run the pressure rise was dramatic and I brought them down to 35psi again. from there they stabilized and by the third run they were 35psi before and after the run. I accidently left the pyrometer at home so no temperature data available for this first event. Ambient was about 85 degrees. My settings are 2 degrees negative front and 2.5 negative rear. What experiences have you guys had with these tires? What pressures have you run? (IMG:style_emoticons/default/driving.gif) |
Trekkor |
Jun 24 2006, 02:12 PM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
Still searching for pressures...
Check sidewall rollover with chalk or shoe polish. You should be using all the tire right to the sholuder markings " Δ ". Have them remounted outside-in to maximize wear after a few events. KT |
Lo-Fi Version | Time is now: 8th June 2024 - 04:18 PM |
